Simplex Tree data structure for representing simplicial complexes. More...
Public Types | |
typedef Options::Filtration_value | Filtration_value |
Type for the value of the filtration function. More... | |
typedef Options::Simplex_key | Simplex_key |
Key associated to each simplex. More... | |
typedef Options::Vertex_handle | Vertex_handle |
Type for the vertex handle. More... | |
typedef Dictionary::iterator | Simplex_handle |
Handle type to a simplex contained in the simplicial complex represented by the simplex tree. | |
Range and iterator types | |
The naming convention is Container_content_(iterator/range). A Container_content_range is essentially an object on which the methods begin() and end() can be called. They both return an object of type Container_content_iterator, and allow the traversal of the range [ begin();end() ). | |
typedef boost::transform_iterator< return_first, Dictionary_it > | Complex_vertex_iterator |
Iterator over the vertices of the simplicial complex. More... | |
typedef boost::iterator_range< Complex_vertex_iterator > | Complex_vertex_range |
Range over the vertices of the simplicial complex. | |
typedef Simplex_tree_simplex_vertex_iterator< Simplex_tree > | Simplex_vertex_iterator |
Iterator over the vertices of a simplex. More... | |
typedef boost::iterator_range< Simplex_vertex_iterator > | Simplex_vertex_range |
Range over the vertices of a simplex. | |
typedef std::vector< Simplex_handle > | Cofaces_simplex_range |
Range over the cofaces of a simplex. | |
typedef Simplex_tree_boundary_simplex_iterator< Simplex_tree > | Boundary_simplex_iterator |
Iterator over the simplices of the boundary of a simplex. More... | |
typedef boost::iterator_range< Boundary_simplex_iterator > | Boundary_simplex_range |
Range over the simplices of the boundary of a simplex. | |
typedef Simplex_tree_complex_simplex_iterator< Simplex_tree > | Complex_simplex_iterator |
Iterator over the simplices of the simplicial complex. More... | |
typedef boost::iterator_range< Complex_simplex_iterator > | Complex_simplex_range |
Range over the simplices of the simplicial complex. | |
typedef Simplex_tree_skeleton_simplex_iterator< Simplex_tree > | Skeleton_simplex_iterator |
Iterator over the simplices of the skeleton of the simplicial complex, for a given dimension. More... | |
typedef boost::iterator_range< Skeleton_simplex_iterator > | Skeleton_simplex_range |
Range over the simplices of the skeleton of the simplicial complex, for a given dimension. | |
typedef std::vector< Simplex_handle > | Filtration_simplex_range |
Range over the simplices of the simplicial complex, ordered by the filtration. | |
typedef Filtration_simplex_range::const_iterator | Filtration_simplex_iterator |
Iterator over the simplices of the simplicial complex, ordered by the filtration. More... | |
Public Member Functions | |
bool | operator== (Simplex_tree &st2) |
Checks if two simplex trees are equal. | |
bool | operator!= (Simplex_tree &st2) |
Checks if two simplex trees are different. | |
Simplex_handle | simplex (Simplex_key idx) const |
Returns the simplex that has index idx in the filtration. More... | |
void | assign_filtration (Simplex_handle sh, Filtration_value fv) |
Sets the filtration value of a simplex. More... | |
Vertex_handle | null_vertex () const |
Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicial complex. | |
size_t | num_vertices () const |
Returns the number of vertices in the complex. | |
size_t | num_simplices () |
returns the number of simplices in the simplex_tree. | |
int | dimension (Simplex_handle sh) |
Returns the dimension of a simplex. More... | |
int | upper_bound_dimension () const |
Returns an upper bound on the dimension of the simplicial complex. | |
int | dimension () |
Returns the dimension of the simplicial complex. More... | |
template<class SimplexHandle > | |
bool | has_children (SimplexHandle sh) const |
Returns true if the node in the simplex tree pointed by sh has children. | |
template<class InputVertexRange = std::initializer_list<Vertex_handle>> | |
Simplex_handle | find (const InputVertexRange &s) |
Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex containing the corresponding vertices. Return null_simplex() if the simplex is not in the complex. More... | |
std::pair< Simplex_handle, bool > | insert_simplex (const InputVertexRange &simplex, Filtration_value filtration=0) |
Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex. More... | |
std::pair< Simplex_handle, bool > | insert_simplex_and_subfaces (const InputVertexRange &Nsimplex, Filtration_value filtration=0) |
Insert a N-simplex and all his subfaces, from a N-simplex represented by a range of Vertex_handles, in the simplicial complex. More... | |
void | assign_key (Simplex_handle sh, Simplex_key key) |
Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'. | |
std::pair< Simplex_handle, Simplex_handle > | endpoints (Simplex_handle sh) |
Siblings * | self_siblings (SimplexHandle sh) |
Siblings * | root () |
void | set_dimension (int dimension) |
Set a dimension for the simplicial complex. More... | |
void | initialize_filtration () |
Initializes the filtrations, i.e. sort the simplices according to their order in the filtration and initializes all Simplex_keys. More... | |
Cofaces_simplex_range | star_simplex_range (const Simplex_handle simplex) |
Compute the star of a n simplex. More... | |
Cofaces_simplex_range | cofaces_simplex_range (const Simplex_handle simplex, int codimension) |
Compute the cofaces of a n simplex. More... | |
template<class OneSkeletonGraph > | |
void | insert_graph (const OneSkeletonGraph &skel_graph) |
Inserts a 1-skeleton in an empty Simplex_tree. More... | |
void | expansion (int max_dim) |
Expands the Simplex_tree containing only its one skeleton until dimension max_dim. More... | |
template<typename Blocker > | |
void | expansion_with_blockers (int max_dim, Blocker block_simplex) |
Expands a simplex tree containing only a graph. Simplices corresponding to cliques in the graph are added incrementally, faces before cofaces, unless the simplex has dimension larger than max_dim or block_simplex returns true for this simplex. More... | |
void | print_hasse (std::ostream &os) |
Write the hasse diagram of the simplicial complex in os. More... | |
bool | make_filtration_non_decreasing () |
This function ensures that each simplex has a higher filtration value than its faces by increasing the filtration values. More... | |
bool | prune_above_filtration (Filtration_value filtration) |
Prune above filtration value given as parameter. More... | |
void | remove_maximal_simplex (Simplex_handle sh) |
Remove a maximal simplex. More... | |
Range and iterator methods | |
Complex_vertex_range | complex_vertex_range () |
Returns a range over the vertices of the simplicial complex. The order is increasing according to < on Vertex_handles. | |
Complex_simplex_range | complex_simplex_range () |
Returns a range over the simplices of the simplicial complex. More... | |
Skeleton_simplex_range | skeleton_simplex_range (int dim) |
Returns a range over the simplices of the dim-skeleton of the simplicial complex. More... | |
Filtration_simplex_range const & | filtration_simplex_range (Indexing_tag=Indexing_tag()) |
Returns a range over the simplices of the simplicial complex, in the order of the filtration. More... | |
Simplex_vertex_range | simplex_vertex_range (Simplex_handle sh) |
Returns a range over the vertices of a simplex. More... | |
Boundary_simplex_range | boundary_simplex_range (SimplexHandle sh) |
Returns a range over the simplices of the boundary of a simplex. More... | |
Constructor/Destructor | |
Simplex_tree () | |
Constructs an empty simplex tree. | |
Simplex_tree (const Simplex_tree &complex_source) | |
User-defined copy constructor reproduces the whole tree structure. | |
Simplex_tree (Simplex_tree &&complex_source) | |
User-defined move constructor relocates the whole tree structure. More... | |
~Simplex_tree () | |
Destructor; deallocates the whole tree structure. | |
Simplex_tree & | operator= (const Simplex_tree &complex_source) |
User-defined copy assignment reproduces the whole tree structure. | |
Simplex_tree & | operator= (Simplex_tree &&complex_source) |
User-defined move assignment relocates the whole tree structure. More... | |
Static Public Member Functions | |
static Simplex_key | key (Simplex_handle sh) |
Returns the key associated to a simplex. More... | |
static Filtration_value | filtration (Simplex_handle sh) |
Returns the filtration value of a simplex. More... | |
static Simplex_handle | null_simplex () |
Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simplicial complex. More... | |
static Simplex_key | null_key () |
Returns a key different for all keys associated to the simplices of the simplicial complex. | |
Every simplex \([v_0, \cdots ,v_d]\) admits a canonical orientation induced by the order relation on vertices \( v_0 < \cdots < v_d \).
Details may be found in [7].
typedef Simplex_tree_boundary_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Boundary_simplex_iterator |
'value_type' is Simplex_handle.
typedef Simplex_tree_complex_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Complex_simplex_iterator |
typedef boost::transform_iterator<return_first, Dictionary_it> Gudhi::Simplex_tree< SimplexTreeOptions >::Complex_vertex_iterator |
'value_type' is Vertex_handle.
typedef Filtration_simplex_range::const_iterator Gudhi::Simplex_tree< SimplexTreeOptions >::Filtration_simplex_iterator |
typedef Options::Filtration_value Gudhi::Simplex_tree< SimplexTreeOptions >::Filtration_value |
Must be comparable with <.
typedef Options::Simplex_key Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_key |
Must be an integer type.
typedef Simplex_tree_simplex_vertex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_vertex_iterator |
typedef Simplex_tree_skeleton_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Skeleton_simplex_iterator |
typedef Options::Vertex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::Vertex_handle |
Must be a signed integer type. It admits a total order <.
inline |
std::invalid_argument | In debug mode, if the complex_source is invalid. |
inline |
std::invalid_argument | In debug mode, if sh is a null_simplex. |
inline |
The boundary of a simplex is the set of codimension \(1\) subsimplices of the simplex. If the simplex is \([v_0, \cdots ,v_d]\), with canonical orientation induced by \( v_0 < \cdots < v_d \), the iterator enumerates the simplices of the boundary in the order: \([v_0,\cdots,\widehat{v_i},\cdots,v_d]\) for \(i\) from \(0\) to \(d\), where \(\widehat{v_i}\) means that the vertex \(v_i\) is omitted.
We note that the alternate sum of the simplices given by the iterator gives \((-1)^{\text{dim} \sigma}\) the chains corresponding to the boundary of the simplex.
[in] | sh | Simplex for which the boundary is computed. |
inline |
simplex | represent the n-simplex of which we search the n+codimension cofaces |
codimension | The function returns the n+codimension-cofaces of the n-simplex. If codimension = 0, return all cofaces (equivalent of star function) |
inline |
In the Simplex_tree, the tree is traverse in a depth-first fashion. Consequently, simplices are ordered according to lexicographic order on the list of Vertex_handles of a simplex, read in increasing < order for Vertex_handles.
inline |
Must be different from null_simplex().
inline |
This function is not constant time because it can recompute dimension if required (can be triggered by remove_maximal_simplex()
or prune_above_filtration()
inline |
Returns the two Simplex_handle corresponding to the endpoints of and edge. sh must point to a 1-dimensional simplex. This is an optimized version of the boundary computation.
inline |
The expanded simplicial complex until dimension \(d\) attached to a graph \(G\) is the maximal simplicial complex of dimension at most \(d\) admitting the graph \(G\) as \(1\)-skeleton. The filtration value assigned to a simplex is the maximal filtration value of one of its edges.
The Simplex_tree must contain no simplex of dimension bigger than 1 when calling the method.
inline |
or block_simplex
[in] | max_dim | Expansion maximal dimension value. |
[in] | block_simplex | Blocker oracle. Its concept is bool block_simplex(Simplex_handle sh) |
The function identifies a candidate simplex whose faces are all already in the complex, inserts it with a filtration value corresponding to the maximum of the filtration values of the faces, then calls block_simplex
on a Simplex_handle
for this new simplex. If block_simplex
returns true, the simplex is removed, otherwise it is kept. Note that the evaluation of block_simplex
is a good time to update the filtration value of the simplex if you want a customized value. The algorithm then proceeds with the next candidate.
block_simplex
, so if you examine the complex in block_simplex
, you may hit a few simplices of the same dimension that have not been vetted by block_simplex
yet, or have already been rejected but not yet removed.
inlinestatic |
Called on the null_simplex, it returns infinity. If SimplexTreeOptions::store_filtration is false, returns 0.
inline |
The filtration is a monotonic function \( f: \mathbf{K} \rightarrow \mathbb{R} \), i.e. if two simplices \(\tau\) and \(\sigma\) satisfy \(\tau \subseteq \sigma\) then \(f(\tau) \leq f(\sigma)\).
The method returns simplices ordered according to increasing filtration values. Ties are resolved by considering inclusion relation (subsimplices appear before their cofaces). If two simplices have same filtration value but are not comparable w.r.t. inclusion, lexicographic order is used.
The filtration must be valid. If the filtration has not been initialized yet, the method initializes it (i.e. order the simplices). If the complex has changed since the last time the filtration was initialized, please call initialize_filtration()
to recompute it.
inline |
The type InputVertexRange must be a range of Vertex_handle
on which we can call std::begin() function
inline |
After calling this method, filtration_simplex_range() becomes valid, and each simplex is assigned a Simplex_key corresponding to its order in the filtration (from 0 to m-1 for a simplicial complex with m simplices).
Will be automatically called when calling filtration_simplex_range() if the filtration has never been initialized yet.
inline |
The Simplex_tree must contain no simplex when the method is called.
Inserts all vertices and edges given by a OneSkeletonGraph. OneSkeletonGraph must be a model of boost::EdgeListGraph and boost::PropertyGraph.
The vertex filtration value is accessible through the property tag vertex_filtration_t. The edge filtration value is accessible through the property tag edge_filtration_t.
boost::graph_traits<OneSkeletonGraph>::vertex_descriptor must be Vertex_handle. boost::graph_traits<OneSkeletonGraph>::directed_category can be directed_tag (the fastest, the least RAM use), undirected_tag or even bidirected_tag.
If an edge appears with multiplicity, the function will arbitrarily pick one representative to read the filtration value.
inline |
[in] | simplex | range of Vertex_handles, representing the vertices of the new simplex |
[in] | filtration | the filtration value assigned to the new simplex. |
All subsimplices do not necessary need to be already in the simplex tree to proceed to an insertion. However, the property of being a simplicial complex will be violated. This allows us to insert a stream of simplices contained in a simplicial complex without considering any order on them.
The filtration value assigned to the new simplex must preserve the monotonicity of the filtration.
The type InputVertexRange must be a range for which .begin() and .end() return input iterators, with 'value_type' Vertex_handle.
inline |
[in] | Nsimplex | range of Vertex_handles, representing the vertices of the new N-simplex |
[in] | filtration | the filtration value assigned to the new N-simplex. |
inlinestatic |
The filtration must be initialized.
inline |
make_filtration_non_decreasing()
function is not launching initialize_filtration()
but returns the filtration modification information. If the complex has changed , please call initialize_filtration()
to recompute it.
inlinestatic |
One can call filtration(null_simplex()).
inline |
inline |
Each row in the file correspond to a simplex. A line is written: dim idx_1 ... idx_k fil where dim is the dimension of the simplex, idx_1 ... idx_k are the row index (starting from 0) of the simplices of the boundary of the simplex, and fil is its filtration value.
inline |
[in] | filtration | Maximum threshold value. |
to recompute it. prune_above_filtration()
than it was before. However, upper_bound_dimension()
will return the old value, which remains a valid upper bound. If you care, you can call dimension()
to recompute the exact dimension.
inline |
[in] | sh | Simplex handle on the maximal simplex to remove. |
std::invalid_argument | In debug mode, if sh has children. |
inline |
Returns a pointer to the root nodes of the simplex tree.
inline |
Returns the Siblings containing a simplex.
inline |
This function must be used with caution because it disables dimension recomputation when required (this recomputation can be triggered by remove_maximal_simplex()
inline |
inline |
The order in which the vertices are visited is the decreasing order for < on Vertex_handles, which is consequenlty equal to \((-1)^{\text{dim} \sigma}\) the canonical orientation on the simplex.
inline |
The \(d\)-skeleton of a simplicial complex \(\mathbf{K}\) is the simplicial complex containing the simplices of \(\mathbf{K}\) of dimension at most \(d\).
[in] | dim | The maximal dimension of the simplices in the skeleton. |
The simplices are ordered according to lexicographic order on the list of Vertex_handles of a simplex, read in increasing < order for Vertex_handles.
inline |
simplex | represent the simplex of which we search the star |
GUDHI Version 3.1.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13 |
