Gudhi::persistent_cohomology::Field_Zp Class Reference
Structure representing the coefficient field \(\mathbb{Z}/p\mathbb{Z}\). More...
Public Member Functions
Element plus_times_equal (const Element &x, const Element &y, const Element &w)
Element times (const Element &y, const Element &w)
Element additive_identity () const
 Returns the additive idendity \(0_{\Bbbk}\) of the field.
Element multiplicative_identity (Element=0) const
 Returns the multiplicative identity \(1_{\Bbbk}\) of the field.
std::pair< Element, Element > inverse (Element x, Element P)
Element times_minus (Element x, Element y)
int characteristic () const
 Returns the characteristic \(p\) of the field.
- Public Member Functions inherited from CoefficientField
 CoefficientField ()
Element characteristic ()
Element multiplicative_identity ()
void plus_equal (Element x, Element y)
Additional Inherited Members
- Public Types inherited from CoefficientField
typedef unspecified Element
 Type of element of the field. More...
Detailed Description
Member Function Documentation
◆ inverse()
std::pair<Element, Element> Gudhi::persistent_cohomology::Field_Zp::inverse ( Element  x,
Element  P
inline
Returns the inverse in the field. Modifies P. ???
◆ plus_times_equal()
Element Gudhi::persistent_cohomology::Field_Zp::plus_times_equal ( const Element &  x,
const Element &  y,
const Element &  w
inline
Set x <- x + w * y
◆ times()
Element Gudhi::persistent_cohomology::Field_Zp::times ( const Element &  y,
const Element &  w
inline
Returns y * w
◆ times_minus()
Element Gudhi::persistent_cohomology::Field_Zp::times_minus ( Element  x,
Element  y
inline
Returns -x * y.
The documentation for this class was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
