Global distance functions. More...
Go to the source code of this file.
Classes | |
class | Gudhi::Euclidean_distance |
Compute the Euclidean distance between two Points given by a range of coordinates. The points are assumed to have the same dimension. More... | |
class | Gudhi::Minimal_enclosing_ball_radius |
Compute the radius of the minimal enclosing ball between Points given by a range of coordinates. The points are assumed to have the same dimension. More... | |
GUDHI Version 3.1.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13 |
