Tangential complex reference manual
class gudhi.TangentialComplex
Bases: object
The class Tangential_complex represents a tangential complex. After the computation of the complex, an optional post-processing called perturbation can be run to attempt to remove inconsistencies.
__init__()
TangentialComplex constructor.
Parameters
  • intrisic_dim (integer) – Intrinsic dimension of the manifold.
  • points (list of list of double) – A list of points in d-Dimension.
Or
Parameters
off_file (string) – An OFF file style name.
compute_tangential_complex()
This function computes the tangential complex.
Raises
ValueError – In debug mode, if the computed star dimension is too low. Try to set a bigger maximal edge length value with set_max_squared_edge_length() if this happens.
create_simplex_tree()
Exports the complex into a simplex tree.
Returns
A simplex tree created from the complex.
Return type
SimplexTree
fix_inconsistencies_using_perturbation()
Attempts to fix inconsistencies by perturbing the point positions.
Parameters
  • max_perturb (double) – Maximum length of the translations used by the perturbation.
  • time_limit (double) – Time limit in seconds. If -1, no time limit is set.
get_point()
This function returns the point corresponding to a given vertex.
Parameters
vertex (int.) – The vertex.
Returns
The point.
Return type
list of float
num_inconsistent_simplices()
Returns
The number of inconsistent simplices.
Return type
unsigned
num_inconsistent_stars()
Returns
The number of stars containing at least one inconsistent simplex.
Return type
unsigned
num_simplices()
Returns
Total number of simplices in stars (including duplicates that appear in several stars).
Return type
unsigned
num_vertices()
Returns
The number of vertices.
Return type
unsigned
Sets the maximal possible squared edge length for the edges in the triangulations.
Parameters
max_squared_edge_length (double) – Maximal possible squared edge length.
If the maximal edge length value is too low compute_tangential_complex() will throw an exception in debug mode.
