Simplex_tree/mini_simplex_tree.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Marc Glisse
* Copyright (C) 2015 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <initializer_list>
// Not doing persistence, so we don't need those
static const bool store_key = false;
static const bool store_filtration = false;
// I have few vertices
typedef short Vertex_handle;
// Dictionary should be private, but for now this is the easiest way.
static_assert(sizeof(ST::Dictionary::value_type) < sizeof(Gudhi::Simplex_tree<>::Dictionary::value_type),
"Not storing the filtration and key should save some space");
int main() {
ST st;
/* Complex to build. */
/* 1 */
/* o */
/* /X\ */
/* o---o---o */
/* 2 0 3 */
auto triangle012 = {0, 1, 2};
auto edge03 = {0, 3};
st.insert_simplex_and_subfaces(triangle012);
st.insert_simplex_and_subfaces(edge03);
auto edge02 = {0, 2};
ST::Simplex_handle e = st.find(edge02);
// We are not using filtrations so everything has value 0
assert(st.filtration(e) == 0);
for (ST::Simplex_handle t : st.cofaces_simplex_range(e, 1)) {
// Only coface is 012
for (ST::Vertex_handle v : st.simplex_vertex_range(t)) // v in { 0, 1, 2 }
std::cout << v;
std::cout << '\n';
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
