SimplexTreeOptions.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Marc Glisse
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
25  static const bool store_key;
27  static const bool store_filtration;
29  static constexpr bool contiguous_vertices;
30 };
31
IndexingTag Indexing_tag
Forced for now.
Definition: SimplexTreeOptions.h:17
VertexHandle Vertex_handle
Must be a signed integer type. It admits a total order <.
Definition: SimplexTreeOptions.h:19
Concept describing an indexing scheme (see FilteredComplex) for applying continuous maps to a cell co...
Definition: IndexingTag.h:18
If true, the list of vertices present in the complex must always be 0, ..., num_vertices-1, without any hole.
Definition: SimplexTreeOptions.h:29
Key type used as simplex identifier.
Definition: SimplexKey.h:15
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
FiltrationValue Filtration_value
Must be comparable with operator<.
Definition: SimplexTreeOptions.h:21
Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>.
Definition: SimplexTreeOptions.h:15
SimplexKey Simplex_key
Must be an integer type.
Definition: SimplexTreeOptions.h:23
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
If true, each simplex has extra storage for one Filtration_value, and this value is propagated by ope...
Definition: SimplexTreeOptions.h:27
If true, each simplex has extra storage for one Simplex_key. Necessary for Persistent_cohomology.
Definition: SimplexTreeOptions.h:25
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
