Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>
More...
Public Types | |
typedef IndexingTag | Indexing_tag |
Forced for now. | |
typedef VertexHandle | Vertex_handle |
Must be a signed integer type. It admits a total order <. | |
typedef FiltrationValue | Filtration_value |
Must be comparable with operator<. | |
typedef SimplexKey | Simplex_key |
Must be an integer type. | |
Static Public Attributes | |
static const bool | store_key |
If true, each simplex has extra storage for one Simplex_key . Necessary for Persistent_cohomology . | |
static const bool | store_filtration |
If true, each simplex has extra storage for one Filtration_value , and this value is propagated by operations like Gudhi::Simplex_tree::expansion . Without it, Persistent_cohomology degenerates to computing usual (non-persistent) cohomology. | |
static constexpr bool | contiguous_vertices |
If true, the list of vertices present in the complex must always be 0, ..., num_vertices-1, without any hole. | |
One model for this is Gudhi::Simplex_tree_options_full_featured
. If you want to provide your own, it is recommended that you derive from it and override some parts instead of writing a class from scratch.
GUDHI Version 3.1.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13 |
