Witness_complex/example_witness_complex_off.cpp
#include <sys/types.h>
#include <sys/stat.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Euclidean_witness_complex.h>
#include <gudhi/pick_n_random_points.h>
#include <gudhi/choose_n_farthest_points.h>
#include <gudhi/Points_off_io.h>
#include <CGAL/Epick_d.h>
#include <iostream>
#include <fstream>
#include <ctime>
#include <string>
#include <vector>
using K = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>;
using Point_d = K::Point_d;
using Point_vector = std::vector< Point_d >;
int main(int argc, char * const argv[]) {
if (argc != 5) {
std::cerr << "Usage: " << argv[0]
<< " path_to_point_file number_of_landmarks max_squared_alpha limit_dimension\n";
return 0;
std::string file_name = argv[1];
int nbL = atoi(argv[2]), lim_dim = atoi(argv[4]);
double alpha2 = atof(argv[3]);
clock_t start, end;
Gudhi::Simplex_tree<> simplex_tree;
// Read the point file
Point_vector point_vector, landmarks;
Gudhi::Points_off_reader<Point_d> off_reader(file_name);
if (!off_reader.is_valid()) {
std::cerr << "Witness complex - Unable to read file " << file_name << "\n";
exit(-1); // ----- >>
point_vector = Point_vector(off_reader.get_point_cloud());
std::cout << "Successfully read " << point_vector.size() << " points.\n";
std::cout << "Ambient dimension is " << point_vector[0].dimension() << ".\n";
// Choose landmarks (decomment one of the following two lines)
// Gudhi::subsampling::pick_n_random_points(point_vector, nbL, std::back_inserter(landmarks));
Gudhi::subsampling::choose_n_farthest_points(K(), point_vector, nbL, Gudhi::subsampling::random_starting_point, std::back_inserter(landmarks));
// Compute witness complex
start = clock();
Witness_complex witness_complex(landmarks,
point_vector);
witness_complex.create_complex(simplex_tree, alpha2, lim_dim);
end = clock();
std::cout << "Witness complex took "
<< static_cast<double>(end - start) / CLOCKS_PER_SEC << " s. \n";
std::cout << "Number of simplices is: " << simplex_tree.num_simplices() << "\n";
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
