This file includes common file reader for GUDHI. More...
Go to the source code of this file.
Functions | |
void | Gudhi::read_points (std::string file_name, std::vector< std::vector< double >> &points) |
Read a set of points to turn it into a vector< vector<double> > by filling points. More... | |
template<typename Graph_t , typename Filtration_value , typename Vertex_handle > | |
Graph_t | Gudhi::read_graph (std::string file_name) |
Read a graph from a file. More... | |
template<typename Vertex_handle , typename Filtration_value > | |
bool | Gudhi::read_simplex (std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil) |
Read a face from a file. More... | |
template<typename Simplex_key , typename Filtration_value > | |
bool | Gudhi::read_hasse_simplex (std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil) |
Read a hasse simplex from a file. More... | |
template<typename Filtration_value > | |
std::vector< std::vector< Filtration_value > > | Gudhi::read_lower_triangular_matrix_from_csv_file (const std::string &filename, const char separator=';') |
Read a lower triangular distance matrix from a csv file. We assume that the .csv store the whole (square) matrix. More... | |
template<typename OutputIterator > | |
void | Gudhi::read_persistence_intervals_and_dimension (std::string const &filename, OutputIterator out) |
std::map< int, std::vector< std::pair< double, double > > > | Gudhi::read_persistence_intervals_grouped_by_dimension (std::string const &filename) |
std::vector< std::pair< double, double > > | Gudhi::read_persistence_intervals_in_dimension (std::string const &filename, int only_this_dim=-1) |
Graph_t Gudhi::read_graph | ( | std::string | file_name | ) |
Graph_t | Type for the return graph. Must be constructible from iterators on pairs of Vertex_handle |
Filtration_value | Type for the value of the read filtration |
Vertex_handle | Type for the value of the read vertices |
File format: 1 simplex per line
Dim1 X11 X12 ... X1d Fil1
Dim2 X21 X22 ... X2d Fil2
etc
The vertices must be labeled from 0 to n-1. Every simplex must appear exactly once. Simplices of dimension more than 1 are ignored.
bool Gudhi::read_hasse_simplex | ( | std::istream & | in_, |
std::vector< Simplex_key > & | boundary, | ||
Filtration_value & | fil | ||
Dim1 k11 k12 ... k1Dim1 Fil1
Dim2 k21 k22 ... k2Dim2 Fil2
etc
The key of a simplex is its position in the filtration order and also the number of its row in the file. Dimi ki1 ki2 ... kiDimi Fili means that the ith simplex in the filtration has dimension Dimi, filtration value fil1 and simplices with key ki1 ... kiDimi in its boundary.
std::vector<std::vector<Filtration_value> > Gudhi::read_lower_triangular_matrix_from_csv_file | ( | const std::string & | filename, |
const char | separator = ';' |
Square matrix file format:
0;D12;...;D1j
D21;0;...;D2j
Dj1;Dj2;...;0
lower matrix file format:
D21;
D31;D32;
Dj1;Dj2;...;Dj(j-1);
void Gudhi::read_persistence_intervals_and_dimension | ( | std::string const & | filename, |
OutputIterator | out | ||
Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death The output iterator out
is used this way: *out++ = std::make_tuple(dim, birth, death);
where dim
is an int
, birth
a double
, and death
a double
. Note: the function does not check that birth <= death.
inline |
Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death The return value is an std::map<dim, std::vector<std::pair<birth, death>>>
where dim
is an int
, birth
a double
, and death
a double
inline |
Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death If only_this_dim
= -1, dimension is ignored and all lines are returned. If only_this_dim
is >= 0, only the lines where dimension = only_this_dim
(or where dimension is not specified) are returned. The return value is an std::vector<std::pair<birth, death>>
where dim
is an int
, birth
a double
, and death
a double
inline |
File format: 1 point per line
X11 X12 ... X1d
X21 X22 ... X2d
etc
bool Gudhi::read_simplex | ( | std::istream & | in_, |
std::vector< Vertex_handle > & | simplex, | ||
etc
GUDHI Version 3.1.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13 |
