Concept describing the requirements for a class to compute persistent homology. More...
Public Types | |
typedef unspecified | Filtered_complex |
Type of filtered cell complex on which persistent homology is computed. More... | |
typedef unspecified | Coefficient_field |
Type of coefficients to be used for computing persistent homology. More... | |
typedef unspecified PersistentHomology::Coefficient_field |
Must be a model of concept CoefficientField.
typedef unspecified PersistentHomology::Filtered_complex |
Must be a model of concept FilteredComplex.
GUDHI Version 3.1.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13 |
