Simplex_tree/simplex_tree_from_cliques_of_graph.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Clément Maria
* Copyright (C) 2014 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <ctime>
#include <string>
#include <utility> // for std::pair
using namespace Gudhi;
typedef int Vertex_handle;
typedef double Filtration_value;
typedef boost::adjacency_list < boost::vecS, boost::vecS, boost::undirectedS,
boost::property < vertex_filtration_t, Filtration_value >,
boost::property < edge_filtration_t, Filtration_value > > Graph_t;
int main(int argc, char * const argv[]) {
if (argc != 3) {
std::cerr << "Usage: " << argv[0]
<< " path_to_file_graph max_dim \n";
return 0;
std::string filegraph = argv[1];
int max_dim = atoi(argv[2]);
clock_t start, end;
// Construct the Simplex Tree
start = clock();
auto g = read_graph<Graph_t, Filtration_value, Vertex_handle>(filegraph);
// insert the graph in the simplex tree as 1-skeleton
st.insert_graph(g);
end = clock();
std::cout << "Insert the 1-skeleton in the simplex tree in "
<< static_cast<double>(end - start) / CLOCKS_PER_SEC << " s. \n";
start = clock();
// expand the 1-skeleton until dimension max_dim
st.expansion(max_dim);
end = clock();
std::cout << "max_dim = " << max_dim << "\n";
std::cout << "Expand the simplex tree in "
std::cout << "Information of the Simplex Tree: " << std::endl;
std::cout << " Number of vertices = " << st.num_vertices() << " ";
std::cout << " Number of simplices = " << st.num_simplices() << std::endl;
std::cout << std::endl << std::endl;
std::cout << "Iterator on vertices: ";
for (auto vertex : st.complex_vertex_range()) {
std::cout << vertex << " ";
std::cout << std::endl;
std::cout << "Iterator on simplices: " << std::endl;
for (auto simplex : st.complex_simplex_range()) {
std::cout << " ";
for (auto vertex : st.simplex_vertex_range(simplex)) {
std::cout << "Iterator on Simplices in the filtration, with [filtration value]:" << std::endl;
for (auto f_simplex : st.filtration_simplex_range()) {
std::cout << " " << "[" << st.filtration(f_simplex) << "] ";
for (auto vertex : st.simplex_vertex_range(f_simplex)) {
std::cout << "Iterator on Simplices in the filtration, and their boundary simplices:" << std::endl;
for (auto b_simplex : st.boundary_simplex_range(f_simplex)) {
std::cout << " " << "[" << st.filtration(b_simplex) << "] ";
for (auto vertex : st.simplex_vertex_range(b_simplex)) {
return 0;
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
