Witness_complex/example_nearest_landmark_table.cpp
#define BOOST_PARAMETER_MAX_ARITY 12
#include <gudhi/Simplex_tree.h>
#include <gudhi/Witness_complex.h>
#include <gudhi/Persistent_cohomology.h>
#include <iostream>
#include <fstream>
#include <utility>
#include <string>
#include <vector>
int main(int argc, char * const argv[]) {
using Nearest_landmark_range = std::vector<std::pair<std::size_t, double>>;
using Nearest_landmark_table = std::vector<Nearest_landmark_range>;
Simplex_tree simplex_tree;
// Example contains 5 witnesses and 5 landmarks
Nearest_landmark_table nlt = {
{{0, 0.0}, {1, 0.1}, {2, 0.2}, {3, 0.3}, {4, 0.4}}, // witness 0
{{1, 0.0}, {2, 0.1}, {3, 0.2}, {4, 0.3}, {0, 0.4}}, // witness 1
{{2, 0.0}, {3, 0.1}, {4, 0.2}, {0, 0.3}, {1, 0.4}}, // witness 2
{{3, 0.0}, {4, 0.1}, {0, 0.2}, {1, 0.3}, {2, 0.4}}, // witness 3
{{4, 0.0}, {0, 0.1}, {1, 0.2}, {2, 0.3}, {3, 0.4}} // witness 4
/* distance(witness3, landmark3) is 0, distance(witness3, landmark4) is 0.1, etc. */
Witness_complex witness_complex(nlt);
witness_complex.create_complex(simplex_tree, .41);
std::cout << "Number of simplices: " << simplex_tree.num_simplices() << std::endl;
Persistent_cohomology pcoh(simplex_tree);
// initializes the coefficient field for homology
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
